- 418
- 0
- 0
- Joseph, OR
For the M38A1, Does anyone have a drawing or picture of the transmission crossmember mount? I took my trans and transfer out as a unit and sent it in (to a shop for overhauling) with the crossmember still attached. I got it back as seperate pieces. The studs on the crossmember motor mount are 6" apart and the the holes on the bottom of the trans are 3" apart. What am I missing? Also, I inserted the trans shaft into the bellhousing most of the way, then got the throwout fork in place, then put the trans all the way in. I still have not got the throwout fork up in place and correctly set around the throwout bearing carrier. What a bugger to work through the small access hole. Any tricks here? I also can't see where the little spring hooks to the ??? One end fits in the small hole and boss on the throwout carrier, but I see no place to hook the other end of that spring. I am ready to lift the transfer case and bolt it to the trans, is there any trick to this fittment or do you just bolt it up, put the rear gear on the shaft and tighten and cotter pin the nut? What torque on the nut? Thanks for the help.
