M5 High Speed Tractor
Iyaayas184
Kansas
I am working on an M5 high speed tractor for a local museum and need to find some parts. Is there anyone out there that is a good source for M5 stuff. I need front doors, rear grates that go either side of the radiator(this one has a Detroit Diesel installed) the rear grates are in the mirror position of the front doors except in the back. I also need a canopy as this one was cut off and scrapped by the previous expert owner :x I am also in need of a couple items from the running gear that I am not sure of the nomenclature on.
The item is in the center of the attached picture and seems to be a dampener of some sort to maybe keep tension on the rear wheel. Would a Stuart part work for this also? I need both of them (one for each side). I also need a windshield and frame. I also need a latch to lock the left fron light in position and both rear light sets. In fact I really need all new lights all around. The tractor is in very good condition structurally, mechanically is questionable but it starts in the cold and drives well eventually after it has warmed up considerably. It really isn't a bad vehicle but has had some bastardized mods over the years I am trying to fix.
Thank You for any help!
Robert
steelsoldiers
3,975
Charleston, WV
Sam Winer in OH lists high speed tractors and parts in their ads in Military Vehicles Magazine. They might be able to help you out. I would love to see some pics of the whole tractor. I had tossed the idea of getting a M2 a while back.
DDoyle
80
West Tennessee
Despite having done a book specifically on High Speed Tractors - I don't remember if Stuart parts will interchange.
Kevin Kronlund in Spooner Wisconsin has a parts high speed tractor - I don't remember if it was a M5 or a M4.
Same holds true for Liberty Restorations in Iowa. Both advertise in MVM - and I think contact info is listed in their on-line directory.
Hope this helps!
David Doyle
wgtactical
316
Carrollton, Georgia
Make sure you get photos and accurate description of the parts before they are sent, AND inventory the package on receipt of the parts. I didnt have a very pleasant experience with them (to say the least) :oops:
Iyaayas184
Kansas
Pictures of the M5 I am working on
Here are the pictures of the M5 I am working on.
Elwenil
40
Covington, VA
RE: Pictures of the M5 I am working on
Someone correct me if I am wrong, but I believe the part pictured that you are looking for is the actual coil spring part of the suspension. It's a flat metal coil spring similar in design to what was used on other tracked vehicles of the era.
