Tototex
- 0
- 16
- Newport, Washington
Someone told me that this is my governor but I wanted to check in with you guys and make sure. Its a cylinder shaped object between my steering pump and injector pump. It had 3 springs in it that blew out the bottom and are now resting on my axle. See picture below.
I have a couple questions so I'll list them out.
1.) Do I need to replace just the governor or do I need to replace the injector pump as well?
2.) This 5 ton actually is running off an LDT engine. I do have the injector pump and governor from the old broken LDS engine. Can I use that governor to replace the blown one?
3.) Upon replacing the parts, does any timing or adjustments need to take place? Can anyone point me to some manuals if so?
4.) And lastly, what would cause this part to blow? Am I running to high of RPMs, just old, anything you can think of?
She has been a trooper. I have hauled probably 30 loads of gravel and sand in the last 2 months. I'd like to keep her going!
Thanks in advance!
Jason
Thanks in advance!
Jason
