- 2,885
- 1,493
- 113
- Czech Republic
Time to get on with it.
After a hiatus of more than five years, I now finally am getting back to restoring our M51A2. I had a Dutch student (living in Portugal) over as volunteer, so I finally had the sorely missed Soldier B at my disposal for a few days.
First thing I did was reading back my own threads on SS to get things sharp again (links at the end of the post) and reading up on the TM-20. The little white car in the back is an old Trabant station wagon, I am reading the TM-10.
Then we tried starting the truck. By now, my Hawker Armasafes had given up completely, so we had to try something. One tractor battery and one car battery does not really get it done (it was close). In the end, with two fully charged 140 Ah batteries with cca 850 A and some ether, we managed and got the truck running. And boy, did it ran smooth and, to our big surprise, without much black or any exhaust smoke. Once I figure out how to upload video, I will post it.
Now we were sure it was running, we had to get it to my son's workshop. While I helped prepare the workshop, soldier B decided to continue removing the last three bolts for the bumper and get it off. He almost smashed his finger while trying to do too many things together without help. Hopefully, my new impact toy (Milwaukee M18 Fuel impact wrench) will help avoid that.
We managed to get the truck to the workshop, as distance of 300m, while driving about one or two mph, without brakes and needing soldier B at every left turn to get ANY movement in the steering wheel.
The truck at its new place. The red boiler-like tank is the tank for the 20-ton steam hammer standing just out of sight. The dog is called Aras and it is guarding the property. Its a Central Asian Shepard. If you enter the property, he will kill you by slobbering all over you. We have a 5 feet high fence with a shock wire on the inside to keep him inside (electra is off most of the time). Then again, when he once escaped, he caught a wild pig and killed it without a second thought or serious fight. Just opened those jaws and bite!
The truck is at its place for now, time to start work.
Highest priority:
1) Remove the left fender so I have room to work. That fender has to be repaired as well.
2) Removing the entire steering assembly, check, repack, and overhaul all bearings, steering house, valve systems etc etc to get rid of this problem. I might end up buying a complete new steering assembly from REOMIE if this does not work (last time I asked they had a set for $ 200)
I cleaned and repaired the valve system two years ago (link below). It worked a bit better but still was problematic. Now, without having driven, the wheel will not turn left even with two people hanging on the wheel. That makes it probably a rust problem.
3) Brakes. No movement in the brake pedal at all, then suddenly it broke free and went completely to the floor.
First thing is to take out the MC and airpack and overhaul them. Now 7 years without any maintenance is too long to hope that with a bit of flushing, everything will be OK.
Then same with all wheel hubs and brake cylinders. The lines themselves have been replaced four years ago.
4) I have a second airpack laying here from the 2014 GA Rally, so its time to look at making a dual circuit as well.
5) Body work: doors need repairs, fenders need repairs,
6) everything has to be repainted in original colors ... but what are the original colors. The history and age of the truck is not completely clear. Once I know more I can decide on the best color. I then have to find a European quality equivalent of the Behr paints.
7) Unit history: I am starting up my efforts to find more about the history fo this truck again. Despite a previous indication from 1973, it probably is an older truck from 1965-1968. The Engine definitely is from 1965, the serial number points at that earlier period, in 1973 Kaiser Jeep Corporation did not exist anymore etc.
Some interesting old links
Restoration part I: the Netherlands and street legal
Dump truck to tractor and back: multi-use M51-M52 combo street legal to 93 000 lbs GVW
Markings and colors and age: what should be the real colors after restoration: spoiler: definitely NOT camo.
Front coupling discussion: interesting thread on how to make an alternative front coupling/towing system
Power steering: first effort in the Czech Republic to repair the Ross Hydrapower steering
Highest priority:
