M52 fuel tank vent wanted
M543A2
11
Warsaw, Indiana
Bjorn:
Hello! i have one i took out of a 5T dump fuel tank, but it is not the same as your diagram. It has a float and valve on it, apparently to shut it off if the fuel sloshed too high.
Regards Marti
cranetruck
75
Meadows of Dan, Virginia
Hmm...I'm not really interested in the vent itself, just the plate to fit the opening in the tank with the sucktion tube. The tank is vented elsewhere.
It will be for the small fuel pump that supplies fuel to the fuel burning personnel heater.
maddawg308
746
Front Royal, VA
Ferroequinologist said:
Fuel burning personnel heater? that 757 gets more and more interesting... :D
That's not unique, Adam. My -725 has a rear compartment heater that was run on gasoline, on a branch line from the fuel tank, directly below it. The idea of resurrecting a 40-yr-old gas burning heater sounds a little dangerous to me, so it will be retired and replaced by a engine coolant-powered heater, like most MVs.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
Mike,
I know that the fuel burning heaters aren't really unique. I just thought the fact that a tractor would have one just to heat its own cab, which happens to have a very large heat producing item already protruding in it, makes that setup unique.
Just set that burner up outside on the ground and light it off- it will probably work fine. Or blow half the mountain you live on up. rofl
Now that Bjorn has included other functions of the heater, I can see why they installed it.
