M52 Tractor with M172A1 Low Bed
ikalimnos
Thessalonika Greece
Hello Boys,
I would ask for your expertise if anyone here can help me.
I have a M52 5-ton tractor and I came across a LowBed M172A1 in excellent condition.
I have read that M172A1 was coupled originally with the 10ton M123.
My question is if I can tow the M172A1 with my M52?
Thanks!
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Hello Boys,
Thanks!
Probably has the larger kingpin?
Itll tow it. The truck can handle it. Safely. Will be a slow go of it though. I towed one last month about 50miles behind my 923 and a double axle dolly and she ran 65 no problem.
Sent from my SM-G935P using Tapatalk
NDT
6,307
Camp Wood/LC, TX
Absolutely. The 5 ton is intended to pull the M172A1, but not at the full 25 ton trailer capacity. There should be a data plate on the trailer listing the derate trailer capacity.
1,175
I thought the multi-fuel engined truck's air compressor was underrated for this.
I Know I read it somewhere in a manual.
Are you restricted on width in Greece? The trailer is 115" wide.
BKubu
1,131
Gaithersburg, MD
I believe the M172s have a removable king pin and the trailer should come with both. It has been years since I had one, but I think the king pin is accessible through a door on top above the king pin.
Scrounger
66
Southern, Maryland
The king pin has two ends. There is a locking collar that holds it in place.
