- 206
- 15
- 28
- Brenham, TX
The headlights on my M52A1 are acting weird. In different switch positions the left or right headlight will be either bright or dim. Below is results with different switch positions.
Panel light switch in off positon;
Service- right headlight bright, left headlight dim
Stop and off positions- not lights
BO marker- headlights off, right BO marker on
BO drive- right headlight dim (come on slowly), left headlight bright, right BO marker on, left off.
Panel light switch in park postion
Service- parking lights only, no headlights
Stop and off- no lights
BO marker- right BO marker only
BO drive- left headlight bright, right dim, right BO marker on.
As far as the low beam high beam switch, it works on the bright light only, regardless of panel light lever position.
I am guessing that the left BO marker bulb may just be bad and have nothing to do with the healight probem.
So, what could be causing one of the headlights to be dim and then switch as to which one is dim, depending on the switch positions, and why are the headlights on in BO drive? I have ruled out the switch, since it only has one output for the headlights. An Olive drab posting on the light switch pinout mentions something about a headlight relay for pin H, but I can't find anything about a headlight relay in any of the manuals. I am also lost as to what type of wire short would create this problem.
Anyone want to take a stab at this?
