M52A2 9.00x20 Tire Question
SneakerZed
Casper, WY
OK, I have an M52A2 with NDT 9.00x20 tires on it now. I am looking for new tires and I would like to know if there are any "offroad" 9.00x20 commercial tires that would fit the bill. If I have to purchase new NDT's, then that is fine but, I am trying to find out if there is something else out there that would fit that has an aggressive tread. Thank you
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Goodyear G177's come in 10x20's, There are tons of 11x20's which can be dueled also.
M543A2
11
Warsaw, Indiana
I do not think the 9.00x20 tires were standard issue for this truck anyway, too small. Someone must have changed them. The 9.00x20 typically are on the deuces. It should have 11.00x20. You can find a good set of the military tread tires easily.
Regards Martin
11Echo
92
CT W. R.
I use Michelin XZL's on several of my trucks with great results!.
BEASTMASTER
142
Burgaw, N.C.
most 5 tons had 11:00 x20 s on them. I definitely wouldn't run 9:00s on the front axel. too much weight. blowing a front tire WILL stain you're skivvies, been there
