airbornebandsman
- 16
- 18
- Universal City, TX
M52A2 gremlins
This truck has been giving me issues since I got it. But isn't that part of the fun, lol? So when I picked it up last year the previous owner had hooked up airlines from his other ruck to this one and busted a brake line/the brakes were locked up. I bled the brakes and towed it home. After replacing injector lines/injectors and rebuilding part of the injector pump (and a couple engine runaways). And then replaced the air pack and the busted brake line, bled the brakes she was running and stopping good. Ended up with a front seal needing replaced, I towed her home and ended up hooking the airlines up backwards as I am a genius. The front service glad hand now has air coming out when you push the brake pedal down and the brake pedal goes all the way to the floor. There is pressure going to all the tires as the pedal going all the way to the floor will produce a good burst of fluid, but the even after bleeding the brakes the pedal continues to go to the floor with no resistance. Sort of at a loss of what is failing Master cylinder/air pack or the valve that all the lines go into before the airpack (PIC). Any help would be appreciated, need to get this thing out of the driveway and on the road.
