M52a2/m818 5spd
panzerwillie
121
miami florida
Its the M818 5 SPD OD a direct bolt on for my M52A2 those the clutch have the same spline also does anyone know the gear ratios between both trany one is a direct 5 SPD the other OD 5 SPD
thanks
Westech
CPL
6,104
207
cow farts, Wisconsin
The trans in back of the cummins is a OD trans and the Multi fuel 5 ton is a Direct. You can also tell buy the Gear sequence The OD is the same as the Multi deuce. I think the OD ratio is .76-1
USMC6062
St Augustine, FL
The multifuel 5 ton cargo truck I cut up had a OD transmission in it, and the 800 series style power steering. The truck was overhauled in the late 70's and they must have upgraded it then.
