m54 24v fuel pump
acetomatoco
just grab one off an old 24 volt heater... low flow low pressure is fine as all it does it circulate fuel thru the filters and keeps the IP supplied.
cranetruck
75
Meadows of Dan, Virginia
mill1970 said:
hi i need to put an in line fuel pump on my m54 multifuel truck can any one tell me what sort of flow rate i need from the 24v pump as in tank one is u/s
The in-tank pump will output about 5 gallons/minute openended.
Depending on load, the flow is 1/2 to 1 GPM at about 7 psi when engine is running.
