M54 versus m813 or m814
shapeshifter3735
Florida
Hi there I know there was a post similar to this and I read it but it didn't quite answer all my questions. Sorry I'm a newbie this is my first post here and I'm playing with the idea of buying a military truck and there's three possibilities but due to differences I will probably wind up with two trucks eventually. Here's my predicament I live in North Florida where three hurricanes hit Idalia, Deby, Helene I've had to clean up about 50 trees I also own a mobile home park and I've had several taken out by trees falling on them. The idea is hopefully I can kill three birds with one stone so to speak. I have a big tractor with a front end loader and a backhoe That's how I've been cleaning up most of the trees so 1) I want a truck to tow My tractor which is easy for any of these. 2) they want a minimum of $6,000 just to move a mobile home and I have five of them. I have a big open field on my property it'd be nice if I had a truck that was capable of dragging the destroyed mobile homes 100 yd over grass to the open field. And 3) Cool Factor. I would only need the truck for work once every other year to twice a year kind of thing That's why I didn't think it was worth buying an f-550 for something I would rarely use.
So the trucks that I like:
1) m35a2
2) m54
3) m813,814 or some variant I think I like the longer bed but not sure.
I think the M35 multi-fuel is cool and it probably get the best mile per gallon I think 11ish but I'm not sure if it would tow the mobile home some people say yes some people say no. Well then I go to the m54 again the multi-fuel is cool I like that idea and the m54 data plate and the m 813 data plate both say they can tow 30,000 lbs on the highway so it would seem the strength is the same at first. But it's my understanding the m813 engine is stronger but I don't know if it's a little bit stronger or a whole lot stronger? Is it possible to put a bigger turbo on the m54 and make it stronger?
So that leaves me with probably the truck I should buy is an m813 or an m814 but I lose my multi-fuel cool factor. I guess what it is If I knew for a fact the m54 could tow the mobile home a hundred yards I think I'd rather have that but if it can't then I'd rather have m813. I guess my problem is I don't know if the m54 can do it or not? Also I believe the M35 it would be easier to get parts but I'm not sure if it's that much different for the other two.
Any guidance would be greatly appreciated.
I hope my rambling made some sense I guess my problem is I'm trying to make a decision and I don't have the needed information.
Thank you
20,760
1) m35a2
2) m54
Thank you
Welcome to the Outfit!
Sounds like you have a pretty good plan so far. The M813/M814 are 5-Ton trucks. The M35 is a Deuce and a Half. The Deuce (assuming it is a newer version) will have an automatic transmission. They aren't bad, but if you are used to jamming gears - you will miss that on the M35. A lot...
The M54 is also a 5-Ton, so any of the three should easily pull a mobile home. Even the Deuce should be able to drag one... Parts really won't be that difficult. Anything on your list should be able to drag your big tractor.
Hope to hear more from you. Just drop us a message and somebody here will respond!
shapeshifter3735
Florida
Al Capone
58
Pearl river la
I would go with the 5 ton over the 2.5 . Main reason - 5 ton has power steering ! And it’s much stronger truck . Be ready to go thru the entire brake system in these old trucks if it had not been done recently . My old m51a2 brakes were terrible . For what your wanting to do you might hunt for the m51a2 like mine which is dump truck . That way you can get more use out of it besides just hauling trailers
DREDnot
588
Phoenix, AZ
I would go with the M809 series 1970-1982. They have a Cummins engine (240 H.P.).
The multifuel (175 H.P.) is not the coolness you would assume. Most have had the multifuel compensator bypassed as they are kind of a liability for many reasons.
The M39 series, 1951-1965 (M54) are also old and finding parts has been a struggle.
For your stated purposes I would recommend an M817 dump truck W/Winch.
Only downside is its a short wheelbase But being able to dump would be a plus for hurricane debris removal
Cool look of the old school Army truck with a better Cummins engine with better tech support and parts availability
