M543A2 front PTO
rizzo
Port Huron, MI
I talked to the drive shaft place today. It will cost me about $200+ to get one made. He needs some info.
1. will the shaft go less than 500 RPM's?
2.what size are the stock u joints? will a 1000 series be strong enough? the next size up is a 1310.
thanks in advance
timntrucks
Ponchatoula LA
rizzo i can take some measurements this friday and send them to you. teh shaft is cheap its the ends that are costly. ill get them and send them to you if you need them
rizzo
Port Huron, MI
I guess the weld together shaft is about 130 then add the ends he said.
how much can you get the ends for?
can you measure the shaft dia. and the width of the u-joint, and the lenghth fro center of u-joint to senter of u-joint? I think that is enough.
GIJoeCzar
26
Sherwood, WI
RE: Re: RE: M543A2 front PTO
Rizzo, I've still got that brand new M809 winch drive shaft; did you determine that it will not fit? Joe
BKubu
1,123
Gaithersburg, MD
Those M809 series winch drive shafts are like hen's teeth. You can't find them when you need them. I paid a pretty penny for the one I needed for my old USMC M817 converted to w/w.
5tonpuller
24
Thompson, Pa
When I re did my shaft (was bent from some one moving it with a fork lift) The shop here told me $40 to replace the tube not the ends or the slip yoke.
timntrucks
Ponchatoula LA
i sent a scetch to you . i dont thing the shafts goes fast at all, but dont know for sure. hope this will help. looks just like some of the front 4x4 shafts i made for the F150, just longer. there tube size is the same. might be worth checking in on that one.
2deuce
147
portland, oregon
front winch drive shaft
I'm interested in your measurements also. I need to have one made. Can't find one out here in Oregon and I'm willing to drive to Idaho, and Washington. Please correct me if I'm wrong, I was told that 5 ton gassers and multi-fuels used the same shaft. The 800 series is longer. Thanks, Greg
rizzo
Port Huron, MI
check out these prices
e-mail:
Kevin
Thanks for the e-mail
Front chain with compression fitting $250
Winch drive shaft with u-joints on each end $425
Plus shipping
Dave Newman
www.easternsurplus.net
-----Original Message-----
Sent: Thursday, December 21, 2006 9:13 PM
To: dave@easternsurplus.net
Subject: MV parts
Hi, I have a M543A2. I need:
Front winch chain
Front clevis terminator for cable to chain
Front winch PTO shaft. 1.25 round to 1.5 round aprox. 74 inches long
Please respond with prices also.
Kevin
1,127
$425?
:shock:
1,807
I bought a gasser M275 from him for $750. Also bought a front and rear deuce axle for $250 and $200 respecively. Thats going back some though.
timntrucks
Ponchatoula LA
rizzo i found a shaft no yoke for 50.00 the yoke is 6 3/8 inches front to back on mine and the cap is just a bit over 1 inch give me a shout if you are interested in the shaft
