M54A2 help needed
Sixwheeler
Thanks for the add this week.bought a 1958 m54a2 duece and half three weeks ago . Bought not running but supposed to have two months ago from a farmer . Cant get fuel to injectors . So i have changed filters they were gummed badly, checked fuse on fuel tank pump .i got fuel to the injecton pump . I took the shutoff valve assembly out not froze up pin ok on shaft and its at the 7 oclock postion ,took center cap off to head plunger pump will shoot fuel out when turn battery power on in truck .i have broke three of the lines loose on top of injector head .its just not getting from top of head to the injectors. ive bled off at secondary filters , i am lost . I am not a mechanic but have watched lots of videos,read alot on problems on these truck fuel injection pumps . Any suggestions? Any one know someone in Indiana to help me get the truck going ? Thanks .
gringeltaube
Staff Member
2,429
Montevideo/Uruguay
So you have a M39-series 5-ton cargo there, with the LDS465-1 Multifuel engine?
(If so, this thread will be moved over to the 5-ton Forum.)
Elk1111
483
Las Cruces NM
It’s either the button under the hydraulic head came off or it’s the bow tie shaped washer on the quill on the hydraulic head. The washer gets wallowed out and doesn’t spin correctly. There is a video online that shows how to take everything apart.
Elk1111
483
Las Cruces NM
On a side note...since you are going to have the injector lines off anyway. Make sure and spray them out real good also.
cattlerepairman
3,237
NORTH (Canada)
I second what Elk said...time to pull the HH off and see what you find. Also time to change the three Orings and never touch the thing again (hopefully).
Sent from my SM-G950W using Tapatalk
AZDeuce
Tonopah, AZ
I currently own a M54A2, love that beast, runs great, but a decade or more ago I had a M52A2 Tractor, basically the same truck. I ran it out of fuel accidently, I had fuel to the injector pump, but it wouldn't start, so I talked to a fellow SS member and friend and he said to have soldier B crank the truck with the throttle pedal to the floor, and then loosen the fuel line at the injector until it was squirting, to get the air out of the line then stop turning over the engine, and reconnect the line, then go to the next injector , and do it all again, until you had bleed all the lines of air, and then it should start up. Worked for me!
