m55 on super singles
mill1970
worcestershire uk england
hello i have just bought a set of 800 series super singles for my m55 fitted front ones on ok but seem to be having a bit of trouble with rear ones with the valve pointing outwards the tyre seems to be to close to the springs am i doing some thing wrong and will i need wheel nuts like thoses on the front thanks for your help
M813rc
3,002
Near Austin, Texas
The rear wheels go on the opposite way around of the front wheels, the same way you would duals, but without the inner wheel. This leaves the rear brake drums inboard of the wheels, which looks a bit odd from behind, but does keep them cool. The single rears use the same lug nuts as the front. If your valve stems point the wrong way, you should be able to loosen and turn them (mine are a "bolt on" type affair).
Cheers
M813rc
3,002
Near Austin, Texas
Thanks Bruce! It was in super mechanical shape when I got it, all I did was change the belts and put in new batteries, then drove it 200+ miles home. Cosmetically wasn't as pretty, but some elbow grease and paint work wonders. I left as much original as I could though.
Cheers
