sangamon
- 0
- 0
- Seattle / Blaine
The other day I noticed that the second steering axle driver side tire on my M656 was flat.
The fellow from Les Schwab said that the triangular o-ring or gasket between the rim and bead had been pinched. He said that the o-ring needed to be replaced, but that Les Schwab didn't carry them. The triangular cross section is a half inch on each side, and the overall diameter is about twenty inches.
I've done many searches on "o-ring", "gasket", "tire", "wheel" in various combinations. The searches almost all find reference to two-piece wheels which are bolted together with a gasket between the parts.
The tires are 395/85 R20 XML Michelin X. Looking at the Michelin Truck Tire Service Manual, I found a brief reference to an o-ring. I'm hoping to be able to buy an o-ring at my local Michelin dealer on Monday. I suppose I can also have an o-ring custom made at Gardico or O-Rings Inc. Or, I can have a tube installed.
Do any of you folks have experience with this tire and wheel setup? Any suggestions?
