M66 ring installation
Jessecordell26
Texas
Does anyone have some pictures of the m66 legs bolted to their locations and to the gun ring ? I just picked up a gun ring with three legs and a reinforcement plate for the cab but would like to see some detailed pictures of the setup to make sure I install it properly. Any help is much appreciated
WillWagner
2,584
Monrovia, Ca.
That pig is HEAVY! The M49 is a better choice, just my opinion, been there, done that. Used it too!
Jessecordell26
Texas
I looked Through the tm but didn’t find anything about how to s cure it to the truck . It did have a lot of useful information though about the m66 itself . I’ll be reading some more when I get off work this evening
thanks for the advice
porkysplace
1,487
mid- michigan
I’m trying to find a source for the adapter plates nsn 19200-7357081 my kit is missing them
That isn't a good NSN
From parttarget ; National Item Identification Number (NIIN) is a nine position numeric string. National Stock Number (NSN) is either a sixteen position numeric string with dashes or a thirteen position numeric string.
blisters13
75
Beaumont in SoCal
Another TM you could look at is TM 9-1005-245-14 dated 1973; it's in the TM section of this site. It has more detail for the vehicle rings than the -13&P.
blisters13
75
Beaumont in SoCal
Can someone PLEASE post the dimensions for the legs? OD, wall thickness, length. Arms too. Sketches. I'd really like to get this done by the end of April.
THANKS
