Shane, sorry, I missed this when you posted it. Hopefully these will suit your needs, if not let me know, I'll take some more.
The batteries mount in two simple racks just inside and below the engine access door. They are held down by a bracket on top with two J-hooks that latch into loops on the rack sides. There is a heat shield between the batteries and the engine, it mounts on the tabs visible on the back of the wheel well and the fan shroud mounting box (just below/beside the exhaust port). Heat shield comes up level with the top of the upper battery. The air filter hangs from the roof above all this, if I can find a picture of another V with that installed, I'll attach it.
Radiator mounts each have a couple of rubber grommet vibration dampers.
The blue hose across the transmission doesn't belong there, it is the forward bilge pump vent line and goes between the radiator corner and the wheel well, it is just loose to give clearance while putting the radiator in.
I included one showing how the hoses go through the fire extinguisher nook and vent overboard through a shrouded exit point in the hull. The fire suppression hose mounts to the fixture visible in the firewall below the bilge hoses.
Since we are talking about the bilge pumps, I included a shot that shows where the one under the engine mounts to the hull floor, the other one is a bit forward under the transmission.
Hopefully all the details mentioned can be seen in the enclosed pictures, but the quality gets reduced way down when they get posted. If there is something you can't make out, let me know, I may be able to either crop that bit and post it higher res, or take a closeup. Or I can email the full size pics to you.
Nothing like good closeups to show the defects in one's paintwork, eh? I can see several spots of primer where I missed with topcoat green
![Rolling Eyes :roll: :roll:](https://www.steelsoldiers.com/images/smilies/icon_rolleyes.gif)
. You can also see where the exhaust joint leaked and spewed all that great black stuff you get when you fire up a rebuilt engine for the first time. Once the restoration is done, I will wash the interior out, it is full of shop dust and dirt now.
Cheers
