M715 bed / M101 trailer bed
M813rc
3,029
Near Austin, Texas
I did some measuring of the M715 and M101 beds. The answer is you could make it work, but an M101 bed will not drop straight on, the problem being that from the center of the axle to the front of the bed is just over 9" longer on the trailer (7" if the bed front frame wasn't there).
To make it work, you'd have to cut a section of the trailer out ahead of the wheel well, or move the entire wheel well back (which sounds much more difficult!),
I'll do some quick diagrams this evening and put them on here so you can see the various measurements.
Cheers
M813rc
3,029
Near Austin, Texas
Okay, hopefully this helps.
Note that the M715 has vertical strengthening frames at the front of the bed that do not come all the way out to the edges, so the bed looks a tad shorter than it is, or if you just measure it from the sides. Those frames are included in the length measurements on the attached diagrams.
The M101 bed has a strengthening frame horizontally across the top front that projects out 2.25" from the front panel of the bed. Again, this is included in my measurements. Also note that the M101 bed is slightly wider at the bottom than at the top.
Dimensions listed do not include the tailgates. M715 tailgate is 2.5" thick, M101 Tailgate is 2.25" thick.
Hopefully all the information you need is on there!
Cheers
glcaines
2,522
Hiawassee, Georgia
If it was me, I'd keep looking for an M715 bed. Even if you have to go a longer distance to find one, that is a whole lot easier than trying to adapt a trailer bed. Also, once finished,your truck with the correct bed is worth more.
Cheers
View attachment 888137 View attachment 888138 View attachment 888139
thank you for your help sorry it
Just curious, why do people ask a question, then not come back to see the answer that others spent their time putting together for them?
It happens a lot! :unsure:
Oh well, hopefully someone else will find the information useful in the future. :)
Cheers
My apologies for not saying thank you.. i have read them.. i try to answer people in a quick manner this time i guess i didn’t there was no disrespect meant..
