M809 Series PTO repair and parts?? (M818 with winch specifically)
Makincold
Mansfield, GA
So my M818 is leaking badly from the PTO assembly
Specifically I believe its the shaft seal
(From TM9-2320-260-34P2) (Figure 448. Transmission Power Takeoff Assembly and Mounting Hardware) (Part #2)
7061272 SEAL,PLAIN ENCASED (Part # 28 from the figure)
I have found this seal several places on the internet but cant find the (
7376534 RETAINER,PACKING) that goes with it (Part #27 from the figure)
(from
TM9-2320-260-34-2) ( 16-41. TRANSMISSION POWER TAKEOFF REPAIR ) ( #6. Remove two boots (9) and retainers (17) from PTO housing) (Discard retainers (17). ) (7. Remove two seals (16) from PTO housing (discard seals)
Do I really have to discard these retainers? Or can I re-use them?
If they cant be re-used where can I buy them?
Anyone have a photo of this part? Or of a similar repair ?
It looks as though (from TM9-2320-260-34-2) that I can change these seals with the PTO still attached to the transmission? Or do I have to remove the PTO and do this on a bench?
Scar59
41
Mt. Eden, KY
Tim,
A lot of hardware can be re-used in a pinch, retainers (snap rings, cotter pins, self locking nuts etc.) The military had bins of new hardware and if available, use it. The seals can be replaced from under the truck. You can sit right up under there and get it done. The aft seal is pretty easy for some one with two left hands. Use the correct tools/snap ring pliers and it come right apart.
JC
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
No, don't discard them...!
This "retainer" (=cup) only holds the dust boot in place. Even with the boot still intact it can easily be pried out of the bore, with no damage or distortion- and thus, can be re-used.
Say so if you need more than the pics below; or if you want dimensions, eventually...
G.
