M816 air lines
EO2NMCB
23
DeSoto, MO
My m816 is missing some air lines at the winch/wrecker controls at the rear of the truck. Fig 387 of the 34p-2 is not the best of where they run to. Does any one have any pic's of where of where the lines are running to?
zebedee
conceptualizer at large
701
Central NY
Having trouble following your references; 24P - 2 has a fig 387 but not relevant and 34 - 2 doesn't list fig's......? However -
816 winch air.jpgThere are two controls there #'s 8 and 11 (from the -10 TM, page 2-120)
One is for the clutch (engine -transmission) the other is for the rear winch cable tensioner over on the opposite side from the controls.
Hope this isn't a "derr" statement.
73m819
319
gainesville, ga.
There is ONE air supply, it tees , one line goes to the clutch control, from hear the line goes to the clutch control air pot that is on the right side of the bell housing, the other line goes to the rear winch tensioner control then to the tensioner.
EO2NMCB
23
DeSoto, MO
I have Air to the tee, but was missing both lines from there . So on the clutch disengage Johnny bar, does it matter which side is the air input? And if I'm understanding correctly the other line off the tee goes to the winch tensioner, The output from the wench tensioner then goes to the brake chamber looking pot on the passenger side by the winch?
73m819
319
gainesville, ga.
Yes on the tensioner, either side should work for the clutch, if there is a issue, switch the lines.
