M816 brake issue
dreameweaver
killdeer north dakota
I have an M816 wrecker, when I set the brakes to use the winch the brakes will not release. The micro brake switch works well. It says to release step on pedal. Not sure if there is something else that may be wrong, so if anyone has ran into this problem any help would be great.
73m819
319
gainesville, ga.
Need to step REAL hard on the brake peddle (harder then you did to set them), I have the same issue on the 819
1,177
I've never had that issue.
73m819
319
gainesville, ga.
Think it depends on how hard the brakes are set in the first place, If I just use stopping brake pressure, they release fairly easy, if I really press the brake peddle down then set them, then it takes a bit of pressure to release them
1,177
Found this on Mico's site.
The brake lock does not incorporate a pressure limiting
function. Therefore, the operator should avoid
excessive brake pedal force when applying the brake
lock. Excessive force causes high pressure to be
locked in the brakes which can be difficult to release.
Changes in outside temperature can cause locked
up pressure to increase or decrease. A rise in temperature
can cause increased pressure in the brake
system which can lead to damaged brake system
components and made it difficult to release locked
brake pressure. To minimize the effects of temperature
changes, the brake lock must be released and reapplied
every hour.
gimpyrobb
dumpsterlandingfromorbit!
27,786
752
Cincy Ohio
Sounds like you could just crack a bleeder open and release the pressure. Then they will either release on their own, or lower the peddle pressure to release the brakes.
1,177
So, today I had an interesting failure with the M819.
The steel brake line from Master Cylinder failed while my Mico Brake was engaged(when I went to release the brake). Without the ability to build brake line pressure, I was not able to release the Mico Brake.
I tried pressing the button a few times, while trying to move the truck, eventually it released.
I only moved it a few feet to a better location, to repair the line in the near future.
fwiw, My manual parking brake works fine, and it was chocked when the failure occurred.
