M816 hoist winch cable replacement
pistonring
Elkton MD
I have a main hoist cable to replace on my M816 wrecker. I am using a three part line if it makes a difference. I have TM 9-2320-260-20-3-4 and it explains the change out well. I would like to have a new cable on hand when I take the old cable off so I can put it back together the same day. Can someone help with the size and length of cable needed? I could measure with a tape measure but I would rather do it the right way and start with the right length the first time. Any particular grade or type of cable recommended? What do you guys use?
Thanks,
Dave in Elkton MD just 1/2 hour up the road from Aberdeen
Stonepicker1
77
Coconut Creek, Florida
I get this info when I looked up the wire rope part number(7699767)
This is the same cable that is used on the M936 wrecker. (in the TM 9-2320-272-10 for the M936 it has a lenght of 95 feet 5 inch)
DIAMETER
0.500 INCHES NOMINAL ROPE
LAY METHOD
RIGHT REGULAR ALL LAYERS
BREAKING STRENGTH
23000.0 POUNDS NOMINAL
CORE CONSTRUCTION
FIBER
PREFABRICATION FORM
PREFORMED
MATERIAL
STEEL IMPROVED PLOW OVERALL
MATERIAL DOCUMENT AND CLASSIFICATION
RR-W-410 FED SPEC SINGLE MATERIAL RESPONSE OVERALL
STYLE DESIGNATOR
6 X 19
