halftrack
- 10
- 38
- New Orleans, LA
OK,
Here's the deal. I have a hydraulic leak (bad, 1 week and the whole reservoir is drained) coming somewhere from the center of the turn table. When I look under the truck everyting is wet or damp with hydraulic oil so it is hard to pin point anyone spot. I want to say that it looks like it is coming from the little gear box under the turntable where the pto shaft goes, however I don't believe this is directly in contact with the hydraulic oil in the center hydraulic pump thats above it. Does anyone have any suggestions on what it might be? Its not the hoses and not the hydrualic rams on the boom for sure. I had to replace that coupling in the center before, but I didn't think that is filled with oil.
