M817 Air Blowing out of Top of Transmission
Construction
North Carolina
On the passenger side top of the transmission where the air lines connect to the transfer case - air is blowing out between the the connections where the lines go into the top of the transmission.
Any body know what is wrong?
Cannot operate the truck anymore.
4,756
Poppet valves. A search will yield you a lot of info. The valve controls the sprag in the t-case. You might get away with removing it and tearing apart and cleaning. Otherwise you might have to rebuild or replace it.
Construction
North Carolina
In between the two valves where the airlines connect on top of the transmission - there is a female coupler that moves up and down. It looks like there should be a male air line or similar going to it. What does that do?
Vintage iron
Falmouth Ma.
Patracy hit it on the head! But what cause the valves to blow? What is you air pressure gauge ready. It should not go over 90 PSI. Are you getting any oil out of your air drain?
1,176
Remove the(shuttle valve) air supply line and spray in some lube(wd40 or whatever). Install the hose. Air up and shift from 1 to N to R about 30 times.
The supply line comes off the passenger side frame rail.
The center port is the exhaust. It does not get anything attached to it.
Never seen too much air pressure affect it
Vintage iron
Falmouth Ma.
I have had a few truck come in with this issue. One had a non functional regulator that was supplying to much pressure to the system. This extra air pressure can blow out the poppet valves. The reason I asked about oil in the air system is because if the air compressor is going it will pump oil into the air system and the oil will screw up the air system.
tie6044
42
Blaine, MN
I though I read when that is happening it means the seals are bad on the air actuator on the t-case.
Construction
North Carolina
Oil and air pressure are fine. I have had issues with the front axle engaging and not for awhile. Tried taking off air supply and adding oil - no result.
73m819
319
gainesville, ga.
i though i read when that is happening it means the seals are bad on the air actuator on the t-case.
THIS IS MOST LIKLEY THE CAUSE, not poppet valves, to much air presure, ect., that fitting is the exhaust from the transfer shift cylinder
MyothersanM1
19K M1 Armor Crewman
418
68
Culver City, CA
When mine started blowing like that, I basically tore the whole declutch system apart valve to cylinder. I tried a rebuild on the poppet valve, but it did not cure the problem. I ended up buying a new-in-the-box valve and I'm glad I did. I replaced all the declutch hoses, to include the air supply from the right frame rail, and rebuilt the air cylinder. Operates flawlessly ever since.
As a side note, I also installed a reverse light and back up alarm using an air switch plumbed into the reverse air line...
http://www.steelsoldiers.com/showthread.php?86106-Reversing-Light-Alarm-M809-Series
