M817 dump hydraulic fluid question
masalser
Lake Stevens,WA
Hi,
I've got an M817 that is low on hydraulic fluid in the dump hydraulic reservoir - can somebody tell me what fluid I should use to top it off?
Thanks.
reuben
Spencer TN
I use the cheapest grade of hydraulic oil I can get due to slight leaks, but I think the stuff labeled tractor transmission and hydraulic oil is better.
madsam
M
I used "low ware" hydraulic oil from Walmart. They had it in 5G buckets for $25. Mine leaks a little too.
m16ty
217
Dickson,TN
Just about any hyd. oil or 10wt oil (most hyd oil is 10wt) or even ATF will work in these simple hyd. systems.
