M818 air leak under dash
bigmike
355
Dixon CA.
I found air leaking out the right side of the low air buzzer switch. There is a small hole on the right side of the switch where you can feel the air coming out.
Is this a similiar problem as I've read on deuces?
Some folks have posted how you can take them apart (watch out for the flying spring:p), clean them up a bit and they work again.
Is this correct?
thanks,
ncduece
wilmington nc
same problem. ive tried to repair,clean mine no luck the old rubber is just to hard and wont seal back up. pm me if you need a good used one for $25
bigmike
355
Dixon CA.
I'll do the "plug it to make it go away":lol: solution.
Groundog, I'm glad to be back also. Thanks.
Hammer
396
Winlock, WA
Mine was leaking, pulled it apart to clean it, and I literally only wiped some small amounts of oily stuff out, and it works perfectly now.
It is the same part as the deuce btw, so getting another one is just a deuce part if you don't just plug the hole first.
