- 241
- 201
- 43
- Marion, AR.
Driving the M818 around today, nothing long distance about 20 miles or so. I've noticed several electrical problems while driving around. The first was ALL the lights went out. All the lights, headlights, park lights, turn signals, brake lights, and dash lights! They came back on, and I returned home and made some observations. While parked, the lights shut off by themselves twice. Both times I had to turn the light switch to the off position and back to the on position. I swore I heard a click sound when it turned off the second time when the truck was parked. Any ideas as where to start would be appreciated.
My other problem is a little easier to diagnose. My passenger side rear turn signal does not work. My brake lights work, but the turn signal doesn't. I was thinking of examining the plug for the rear harness, checking for a cut/frayed wire in the back, or checking the plug for the turn signal switch.
I recently did an upgrade on the alternator with a delco 100amp 24v replacement. I had problems with the rear turn signal before the upgrade, but nothing with ALL the lights going off.
