tommygun
- 0
- 0
- springfield tn
I recently picked up a M818 from Redstone Arsenal (euc cleared in 9 days ) everythings works but front axle wont engage. Here is what I have tried so far
1. Checked operation of poppet valves on side of transmission ,air comes from front valve in reverse , rear valve when taken out of reverse
2. Checked that air was going through lines to actuator on front of transfer case
3. removed actuator , cleaned and honed , cleaned and lubed piston
4. Checked movement of piston/shift fork , slids freely in and out ,there is no loud thunk when moved
5. Jacked front wheel up , had wheel rotated while moving piston in and out , no difference , could hear some clicking noise from transfer case
6. reassembled , getting air released correctly when shifting into and out of reverse
7. Jacked front wheel up , put in reverse wheel turns both directions ,same in first gear
8. Drove truck up slippery hill no 6x6 in forward gears , but sometimes works in reverse
Any help would be greatly appreciated Thanks
