M818 fuel knock in Cummins
gem1410
42
TOMS RIVER NJ 08527
My M818 has 48k miles--starts fast--idles at 625 rpm--comes up to running temp--it has low power and is very slow getting up to 50mph. It has what sounds like a fuel knock all the way up to 45mph--Over 45mph the noise goes away and the engine sounds OK--The noise comes back as soon as I go under 45mph--Any ideas what this might be--Thanks
gem1410
42
TOMS RIVER NJ 08527
may have a bad injector--will try cracking each line to find the bad one--I have never worked on these engines--how hard is it to get at the injectors----Thanks
bigmike
355
Dixon CA.
cracking the line will do what? what are you looking for when doing this?
gem1410
42
TOMS RIVER NJ 08527
find which injector is not working--I am looking for the engine to run rough if the injector is good with the fuel line cracked and for the engine to run the same with a bad injector cracked at the fuel line
WillWagner
2,578
Monrovia, Ca.
If you have an 818, you have an 855...no injector lines to crack. Does it miss at start up? The N/A 855's do have a rattling sound on acceleration. You say you see unburnt fuel out the pipe. What color is it?
bigmike
355
Dixon CA.
got it...thanks
Floridianson
2,498
Interlachen Fl.
The fuel looks clean although I will check the filter on monday
Don't forget the fuel screen on the TP under the big flat head screw on top.
Could your emergency shut down valve not be reset all the way. How are the rubber lines on the transfer valve?
