M818 mud flap bracket help needed
pistonring
Elkton MD
I am trying to get the truck pictured in my avatar ready for the road. Part of the state inspection stuff includes clearance lights and tag lights.I hate to cob the truck up with these trashy looking lights but I must attempt to follow the law even if i don't agree with it. :evil: The other thing that I need to add is the missing "goat ear" mud flap brackets. I would prefer to have the correct brackets but if I can't find the right ones I can cut them from steel plate if someone would be kind enough to get me some measurements of the "goat ear" shaped piece that the square mud flap support rod bolts to. The "goat ear" looks to be about 6-8 inches long with 3 holes at the front where it bolts to the frame. See the GL picture of the brackets on a couple of recently sold trucks. They are about 3/8" or 1/2" thick. If I have to make them i might as well do it right, so if anyone would kindly take a tape measure out and get some sizes I can make some chips. Even better yet, anyone have a couple of these brackets on a parts truck? :?: I can always get civvy mud flaps and the square bars that hold them and paint them with 383. Please help me get this M818 on the road.
Thanks,
Dave
powerhouseduece
Pasadena, Md
The plates are 3/8". I have a set you can make a template of but already sold them to another member. The suqare stock hangers, the cast mounting brackets, and the mudflaps can be picked up at Fleet Pride in Curtis Bay.
Its good to see another M818 in MD.
Hammer
398
Winlock, WA
Holy Cow! That is a lot of cash for some brackets!
Maybe I will keep those things I have on the back of my 818! They are bent (don't want to know what they hit or backed into to bend them), and I was just going to pull them off and make my own. Maybe now I will keep them!
cranetruck
75
Meadows of Dan, Virginia
Following this with interest. This is what I have so far for my 5-tonner, I plan on making the remaining parts detachable, since they'll be in the way off-road.
The B&W image is from ca 1968.
What is required in the way of clearance lights? The back-up light and license plate illumination were easy enough to add....
jcappeljr
27
Delta, PA.
Pistonring,I have mud flaps with the brackets for the 818.If you are interested call me at 410-808-5227,I am not to far from you.JOHN.
rosco
Delta Junction, Alaska
Those civilian mud flap hangers come in an offset version too. You really only want them on the truck, when bobtailing anyway.
Lee in Alaska
pistonring
Elkton MD
Thanks for all of the helpful posts guys. :smile: Anybody have a picture of the flaps strapped to the toolbox? :?: I can't visualize how they would fit without hanging out somewhere. :?: What kind of straps are used? Nice OD stuff or do you use civvy bungee cords? I hope to get this M818 on the road before cold weather. With your help and encouragement it just might happen. Aberdeen 2010 here we come.:-D
Thanks again,
Dave
KsM715
142
St George Ks
If I can piggy back on this thread, does anyone have a close up pic of the way the bracket is bolted to the truck? My M818 does not have brackets on it and just like pics 2 and 3 above my truck has only one hole in the frame rail at the back. Does the lower rivet need to be removed?
groundog
wittmann,az
the straps for the mud flps are very similar to the gas can straps--my tractor had the strapa but I went to a surplus store and found some straps that worked for 3 dollars each
powerhouseduece
Pasadena, Md
My truck had them on the back of the tool box and always wondered what they were for. Too bad I found out now after I mounted a atenna on the tool box. That and I dont think 36" mudflaps would roll up and fit in there anyway.
70deuce
121
Franktown, CO
I bought a Betts set model B69 (straight arms, 9" offset) and they came with the mounts you see in the pics. B69 is a set of two A69 arms that are shown in the Betts catalog. They look close to the tires but forward motion and air flow does keep them off the rear set of tires. No rub matks yet. Easy to remove and replace and they definitely need to removed when pulling a trailer. Bought them from Midwest Wheel Company, (512) 265-1491. Website, Midwestwheel.com They were relatively cheap and look pretty good. $35.62 a pair with a $12.68 UPS charge. Also attached is a Betts catalog.
70deuce
121
Franktown, CO
Forgot to say I got the mudflaps themselves on Ebay for cheap. Also if you are having trouble opening the Betts catalog right click on it and select open in new window. Takes a little time but it will open up.
pistonring
Elkton MD
Mudflaps are installed thanks to SS
Many thanks to the members of Steel Soldiers here as I was able to get connections made for a pair of correct military mud flaps complete with the right bracket. I have them installed ready for the first road trip this weekend. For the benefit of the next guy that has the same problem I got the part number of the "goat ear" shaped steel plate bracket that bolts to the frame. It is part number 2300853. Looks to be a piece of 3/8" steel plate with 6 holes in it. Roughly 3" x 8" with rounded corners. Got my historic tags today so the 818 is street legal now. Time to get it out and run it a little. ;-)On November 7th I will have the 818 at the Novemberfest held by Cecil County Farm Museum in Elkton MD at 123 Elk Mills Road along with a few other green trucks. And the next weekend I will be at the maryland Elk Neck campout with the other green trucks. Gotta get the green stuff out of my blood before cold weather.:-D Thanks again to SS for the help.
