M818 won't downshift
bigmike
355
Dixon CA.
I took the truck for her first ride in 6 years. She upshifted just fine but downshifting to 4th would result in grinding. I can downshift to 3rd when she slows down enough. Again, upshifting is fine, oil levels good. Any ideas? BTW, transfer case was in high.
deuceman51
10
Scotland South Dakota
Sounds like your RPM are still too high. I have this problem with all M809s that I drive. The motor dang near has to be to idle before you can downshift or else grinding will occur. It shifts a lot different than a deuce.
