m870a1 kingpin
powersmoke18
nj
looking for the 2" king pin that fits an M870a1. any one know where i could get one or have a part number? thanks guys! Bart G.
Castle Bravo
Hundredaire Socialite
222
Arizona
There is no part number, because there is no 2" M870A1 kingpin. That is, to say, there is no stock/OEM 2" kingpin. The trailer was designed for the 3-1/2" fifth wheel tractors. To my knowledge, all of the A1s were manufactured by Shoals American Industries, which no longer exists, so you can't go to them for parts.. I think armed with the correct dimensions and starting with an existing 2" kingpin, you could make (or have made) a working 2" kingpin assembly for the M870A1.
I have a 2" kingpin for my 870A1, but it was manufactured by someone. I could probably get you some dimensions of the kingpin that I have.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Will bump this with some information.
Replacement kingpins for the 870a1 are as follows
For 3.5in and 2in
Overall length : 8.5"
Barrel thickness 4.5
For the Load King 870
3.5in kingpin Load king part# MP5-1639-1.
2.5in kingpin Load King part # MP5-1638
Spec diagram attached of both
zebedee
conceptualizer at large
701
Central NY
I saw there were 5 that came through Wed at the
Albany GA auction
and 4 of them had no king pin. I would have jumped in if they were a lot closer to me and could have gotten dims to make one. Perhaps this is a sign of something to come - we can hope. Pre production of these may be prudent - anyone know if they are a higher grade steel?
simp5782
9,329
Mason, TN
Kingpins are made of either 4320 or 8620 so hard enough
I am having a flip pin made. 4.5in diameter 8620 came in 2ft stock lengths. Going to have it as a 3.5in pin on one side and a 2in on the other with a raised weld in the middle as the hole catch for the pin. So you can simply use 1 pin for everything
3.5in pin is available from loadking for $460
2in pin is $650
simp5782
9,329
Mason, TN
Total length of the pin needs to be 9-9/16" longer than the spec sheets provided. Attached are specs for the 3.5in pin from Castle Bravo.
