Shoals America M870A1 40 ton lowboy. Triple axle, equalizer suspension non air ride. Converted from Dayton to Hub Pilot hubs with 255/70/22.5 low pro. Oil bath hubs. Steel grate deck( comes with extra to replace when it gets damaged) lay down neck. 2in and 3.5in kingpins. Newer spring brake cans, air lines, wire harness. New circuit breaker harness box on neck.
All bearings/hub oil was serviced fall 2024.
Has no bent beams, wheels, or axles.
Comes with 6 extra new recaps and an extra brand new axle. Extra wire harness.
8ft6in upper deck.
32ft rear deck with dovetail.
Has lower landing skids removed so it will ride behind the 915 series trucks. A1 - A4 trucks. included.
Does not come with ramps.
Will go coast to coast everyday with no issues. It has done it several times over.
Located in Mason, TN 38049.
Notarized bill of sale or can get a title for you..TN does not require titles or tags for farm trailers.
Open to offers and partial trades.
16,000
8ft6in upper deck.
16,000
