M872A1 backup lights
ClintA
10
Mule Creek, NM
So I am thinking about putting backup lights on the M872A1 cattle trailer because sometimes the sun goes down before we are done working for the day. Sometimes there is not a pickup to shine the lights on when needed backing up to a loading shute.
So I ask how does one go about wiring it so I can unhook the tractor?
How would a professional MV electrician do this job?
Thanks in advance, Clint
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Well, if you never plan on using the "black out" lights, just use the black out light circuit. All you have to do to turn on the aux lights is move the switch on the 3-lever.
Thats How I did my reverse lights on my deuce.
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
X2
Sent from my SM-G935P using Tapatalk
ClintA
10
Mule Creek, NM
OK, But can you keep your headlights on doing that?
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
Why cut anything out? There are several spare pins in the plug. Other Nato countries use them, but US vehicles don't. Just use pins M & N. And that keeps your blackout system intact. You might have to run new wires to the receptacle on the truck and then on from the plug on the trailer.
gimpyrobb
27,785
748
Cincy Ohio
No
Good to know, I wasn't aware of that.
simp5782
9,322
Mason, TN
You can add a few lights on different switches if you want and just use the standard 4 wire trailer roll of wire you can buy. Then add a 4 flat trailer connector up on the tounge. Then add a 4 flat to the truck side coming from whatever switch you wanted to install if you wanted to use multiple lights to come on at different areas. I use that trailer wiring on mine since it is already together and easier to run than multiple wires and its a quick disconnect
