fslay0435
- 0
- 0
- Laurel, MS
Hello all,
I've been working on an M880, and just got the carter bbd back from being rebuilt. Although the truck now idles and runs fine, I have noticed fuel seeping from around the throttle shaft area, so i'm thinking its got wear there.
Also, the dust cover on top of the carb that covers the floats only has one screw from the factory, so fuel will come out of there if I remove the air cleaner assembly. I wonder if the floats are set too high?
I've already got $100 in the Carter, but I've read where the Motorcraft 2100 is a fairly easy swap to replace the bbd. I don't wanna put any more money in the carter. Anybody tried the motorcraft swap? Which year, make, model carb would I need and what all is involved?
Basilcally looking for a good stock runner, no performance stuff. thanks in advance.
