M880 Fuel Problems: Welp - I'm Out of Ideas
Potomac Valley Organics
Maryland
This old 77 has had a persistent fuel problem for several years. It just chokes out of fuel and stops running. Here's what does NOT appear to be the cause:
1. Dirty fuel tank - removed, cleaned, reattached fuel tank
2. Bad fuel lines - all lines have been replaced
3. Bad rollover valve - removed rollover valve from the system altogether
4. Fuel sending unit - replaced it and made sure its vending properly
5. Bad fuel pump - replaced mechanical fuel pump TWICE and even just put an electric pump on to no avail
6. Bad cam/eccentric - the thing pumps fuel like mad when its not connected to the carb
7. Bad fuel filter - replaced fuel filter twice
8. Vapor lock - insulated all fuel lines and even experimented with a three-port valve
Sometimes she fires up fine. You can watch the fuel almost fill the clear filter. There's always a little bubble in there though. Then, over the course of an hour or so idling - or faster if you're driving - you can watch the fuel filter empty out of fuel and see the bubble get bigger until the carb sucks air and the truck stalls out.
Any ideas lads? Cuz I'm out of them.
foxtrk2
foxboro ma
you said you replaced fuel lines does that also mean you replaced all flexible or rubber lines in the system ? . if not that's where id look sounds like a line colapsing in on itself or a crack some place in the line letting air in
73m819
323
gainesville, ga.
Tank vent, line. or what ever blocked causing a vacuum, had a 63 chevy station wagon do the same thing due to this issue, took forever to find the cause of the issue.
Maryland
Fuel lines are all clean and straight. Replaced the pickup/sending unit in the fuel tank. Vent line to the fueling throat is open.
To be clear, you can disconnect the fuel line at the carb and watch the fuel pump out of there consistently with quite a bit of force - the whole fuel delivery system up to the carburetor seems fine.
The only thing I'm wondering now is the prior owner put a Holley 4 barrel on it. Could that be causing my issue? I'm gonna swap it out with a stock type and see if that doesn't help.
AMGeneral
115
Connelly Springs, NC
I am going to throw this out there, I had a similar situation with a 1973 W100 I owned, same symptoms, it ended up being the fiber(plastic) cam gears that were used in the 318s of that era.
I replaced it with a double roller setup for a 360 engine and it cured the problem.
Just a possible suggestion.
porkysplace
1,493
mid- michigan
Your floats probably need adjusting , there is a screw on the side of the float bowl on Hollys and you want the float set so the fuel just barely trickles out the screw hole on the side.
https://www.youtube.com/watch?v=LKEonVeOXco
Tow4
646
Orlando, FL
Are you sure it's fuel related? Pour a little gas in the carb while cranking to see if it fires.
Maryland
[FONT=Tahoma,Calibri,Verdana,Geneva,sans-serif][/FONT]Tow4 - Yeah it'll fire. Sometimes it runs for hours before shutting off.
porkysplace - Yeah, I'm gonna give this a shot, thanks.
bikeman
501
Ft. Bragg, NC
I'd say it's the carb as well. Not sure what, but if you've fixed or replaced everything up to that point, then it's gotta be what's next.
rchalmers3
30
Irmo, South Carolina
I'll pile on with the carby float adjustment, and add an extremely long shot: If the fuel tank is not venting, that could be a source of fuel starvation. You might try simply removing the fuel cap and running the engine to test this possible issue.
Maryland
Did that. I usually run it with an open gas cap for diagnostics, and just made sure the vent line was clear yesterday.
I'll report back about the carb, thanks.
