M880 MERDC pattern teaser
McGuyver
Utah
Hello all,
Since I couldn't find a copy of the MERDC pattern speciifically for the M880 in print, I decided to draw it in my self, tracing it from the M715:
Here is a shrunken down copy (forum allows no larger than 480X640 pixels) I saved in JPEG. I've actually been using a working copy in TIF that has the colors in a much more sharp cutoff. This makes it easier to do color fills in the "paint" program so I can try out different color schemes. This one is the "Summer, U.S. and Europe-Verdant" pattern. I've also got the "Winter, U.S. and Europe-Verdant", which I think I like better. Tell me what you think. I can upload larger versions of these patterns too if someone can show me where or how to do it.
N1265
Fremont, Ohio
Mcguyver :
Thanks for getting this done.... I have been wanting this for a long time. I tried to "wing it" withought a pattern but I did not like how it turned out.
I will be doing my M880 in the summer pattern 8)
Nick
Elwenil
40
Covington, VA
I have the manual somewhere that has the actual diagram on it for this pattern. I think it might be one of the ones posted here on SS, or it may be one I picked up from LOGSA. I'll have to check when I get home.
McGuyver
Utah
Desert Rat said:
McG,
How about the desert cammo pattern?
here's part of it. Sorry, I've only got one page so far:
P.S. These are shrunk down versions of the larger original I've been working off of. The TIF files are about 800KB each page. when I'm completely finished "cleaning up" these files, I can upload them to the forum. As I stated, the color separation is much more crisp. The JPEG format has a tendency to kind of smear the colors together at the borders.
nattieleather
148
Cleveland, OH
I like the look of the winter pattern.....
Just so you know most units painted one pattern and left it for both summer and winter. Around these parts most of the units painted in the winter pattern. Almost nobody followed the pattern into the bed. They painted the whole truck in color 1 and then did 2-4 on top of it but never bothered with the inside of the bed.
915A-CHIEF
Walpole, NH
The correct pattren is in TB 43-0209. #1 is forest green, #2- brown, #3 is black. This vehicle had a 4 color scheme. they do not show it in the TB. The #4 is tan. It followed the black / brown lines for contrast, reflection.
Chief.
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
I'm pretty sure my print copy of the MERDC pattern has an M880 in it. I'll check it out this evening and see. I might be able to scan it, if you want it for comparison. Those patterns look good! I actually did the same thing for the CUCV pattern when I got my first truck. Not sure what I ever did with those files...
CUCVFAN
47
Jarrettsville, MD
Well, I guess I was mistaken. I know I've seen the pattern somewhere. Now if I can only figure out where....
Elwenil
40
Covington, VA
It definitely exists out there somewhere. I know I have seen it in PDF form also, but I never saved it because I was always more interested in the 3 color patterns, so they are all I saved. The problem is all the majority of the manuals out there are updated versions that don't show the 4 color patterns.
N1265
Fremont, Ohio
This comes from the olive -drab web site,
"When the information in the TC 5-200 color tables is combined with the pattern design for a particular item of equipment or vehicle, any camouflage pattern can be quickly determined. If the actual pattern design is not available, or never was produced, another pattern can be adapted. For example, the M-151 pattern can be adapted for use with any jeep, the M-715 for any pick-up or similar vehicle, and the M-114 for any APC ".
http://www.olive-drab.com/od_mvg_camo_patterns.php
The 4 color pattern that is displayed for the M-715 was authorised to be used on all like vehicles
( M880 ) if you look at pictures of old M880 series trucks you will see evidence that this is how uncle sam painted them, I will post pictures so you can see what I mean, I personally believe that the layout that Mcgiver did is historicaly correct.....
N1265
Fremont, Ohio
Here are some pictures of my truck before the restoration, This is how Uncle Sam had it painted. you can see it is very similar to the M-715 lay out. The brown above the fender wells is where they threw some primer on it to prevent rust......
I also remember reading somewhere that the manual allowed 10% variation of the pattern.
