M886 Camo pattern
McGuyver
Utah
Are you looking for the NATO 3 color pattern, or the original 4 color MERDC pattern? The NATO 3 color pattern can be copied from the CUCV ambulance (M1010?) I have the M880 4 color MERDC pattern, but not the M886. However, all you have to do, is copy it from the M715 abulance variant (M725) In other words, The M880 4 color pattern was identical to the M715 4 color pattern, therefore by extension, if you can find the M725 pattern, you should be able to use it on the M886.
