M915A1 Filter Numbers
AMGeneral
115
Connelly Springs, NC
IF it has the spin on by pass oil filter,your Fleetguard numbers are as follows...
Full flow oil LF670
bypass oil LF777
Fuel FS1000 or FS1212 FYI the FS1000 is a smaller micron filter
WF2071 is the water filter
Transmission outer spin on is a HF6243 or HF6318 is an upgrade filter,also a smaller micron I believe.
No clue on the air filter,never had to replace one.
rcflyer70
Lancaster, Kansas
I believe there are 2 or 3 different possible part numbers for the internal filter kit (filter and O-Ring). You simply need to take the serial number off the transmission and call an Allison transmission parts dealer (I wasn't able to locate a cross to the filter kit - Fram, Wix, etc).
As for the oil, my local Allison dealer said I could use Allison transmission fluid (of coarse Allison recommends this) but it would be cost prohibative. He suggested any transmission fluid rated Allison C-4 (Dexron-III/Mercon) - said they've never had a problem. I used Mach 4 brand. I believe total fluid cost was +/- $90.00.
