m915a1 jake brake quit working
akita91
CREVE COUER , ILLINI
:mrgreen: Hello everybody again :D truck been sitting for 2 months
just finished main job season.time to fix truck and drive .jake brake doesnt work.couple weeks ago i spun around the block and tried to jake it on highway,it worked but responded about few secs after i pressed pedal.now it quit at all.
also,how do i fix fuel level gauge bouncing in the middle and same with oil pressure.kinda erratic.both getting 12v.
what steps do i need to reduce coldstarting time,it was 24f today,it took me about 15-20sec and 3 times to start truck.
Sorry for so many requests at once.i jsut dont want to hijack.ive looked up online about those issues havent found or wasnt smart enough to comprehend :D anyways .
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
they take awhile to start when cold. And they will huff and puff for awhile till they get warmed up... it takes a minute for it to spin up and create enough head and compression to start. A block heater is the only way to reduce cold starts really.
Fuel gauge is probably a bad ground. Clean the ground at the tank and on the frame and re attach it and go from there. Oil pressure could be a sender
On your Jake's you need to see if you have power to your pedal. If you have power then make sure you have power across the switch when it is pushed. Could be just the floor switch. If you have power across both floor switch connectors when you push it then go up to the switch on the engine throttle. If you do not have power there but had it at the floor switch I would suspect a bad wire or transmission switch. If you have power at the engine switch on both terminals with your throttle off then your Jake's should work.
I guess it is not working on any mode select setting?
akita91
Thank u man 😌 gon try today.
I've seen pics av8or posted about air ride ,I haven't seen joint between cab and firewall.as far as I know.i need some pivot bushings instead solid mounts in front of cab as I want to slap 2 airbags in back of cab.
Do u have any idea how to go around fixed valves in firewall to cab and steering wheel shaft.
royalflush55
526
Reydon, OK
Sometimes you can simply tap the jake brake pedal a few times and it will make contact after truck sitting awhile.
akita91
95-3120
49229​
240-33 ohm​
Compatible with most brands​
95-3121
49230​
0-90 ohm​
AC type gauges​
95-3122
49231​
78-10 ohm​
Ford or Chrysler​
95-3124
49595​
10 - 180 ohm​
matches response of VDO models​
95-3123
49594​
Replacement float for
95-3120, 95-3121, & 95-3122​
which one do you think ?
simp5782
9,329
Mason, TN
95-3120
49229​
240-33 ohm​
95-3121
49230​
0-90 ohm​
AC type gauges​
95-3122
49231​
78-10 ohm​
Ford or Chrysler​
95-3124
49595​
10 - 180 ohm​
95-3123
49594​
95-3120
akita91
Can you guys please help to understand,im looking right now in manual and found out current transmission has *speedometer gear cable* which hooks up somewhere behind to actual speedometer ,so how new allison 4500 does it,they mated this old cummins with 4070p. assuming trans sends speed to tcm,tcm shifts and simultaneously sends numbers to speedometer.? if my speedometer right now mechanical,does it mean i have to buy electronic ?
akita91
okay 6hours later figured it out .
1. put in new trans (find out if they can be mated with engine)
2.cut or add driveshaft length
3.convert speedometer to electronic as 4500 doesnt have tachograph provision,only electronic sensor(output speed sensor goes into speedometer,where goes input speed sensor?)
4.add turbo speed sensor to make trans shift correctly
any steps im missing?
kubotaman
124
RI/MI
Check the switch on the foot pedal for the Jake. That was the culprit for erratic operation on ours. Sometimes the Jakes would only kick in after standing on the pedal for a few seconds, sometimes they wouldn't work at all. New switch solved it.
73m819
319
gainesville, ga.
I had a jake stop working on a 915a1 because the throttle shaft switch took a dump, I just wired around it till I could replace it.
