m915a1 pintle towing question.
cornrichard
Galesburg, IL
I picked up a 25,000 lb pintle, air brake flatbed this weekend. I had to remove the gladhands and cap the lines for the fifth wheel trailer hook up. I crawled under the truck to look for shut off valves and did not find any. The rear air lines have shut offs and they worked perfectly. I was surprised that there was not something for the primary air hoses since the truck has all of the other equipment for fifth wheel and pintle towing. I tried just hooking the hoses to the pogo stick. It is vented so that was a no go. Anybody else tried this? Did I miss the easy way?
1,172
Is there anything in the -10TM?
Did you shut off the trailer air supply valve.
