- 7,408
- 2,500
- 113
- Interlachen Fl.
Just my luck two of the batteries went bad and when replacing them found an extra wire. I know I did not bust it off a terminal, The wire does not show up as a ground as per test. The extra wire is in the harness along with the two wires that are on the 24 volt tap. Everything is working fine on the truck. There is enough wire to reach 12 volt pos. Negative post and 24 positive. The extra wire does not have a number tag. Does anyone have a 915A2 that can check to sea if the wire is even used on the 915A2 and if so where is it connected. Tanks.
