M916 power steering foaming
goodguyzy
13
medford oregon
For search purposes.
Problem: Power steering fluid foaming and overflowing out of reservoir.
Found: Sucking air from hose clamp connection at pump (hose that runs from cooler to reservoir)
fix: A few turns on a 5/16 socket, gave it a good torque.
73m819
319
gainesville, ga.
also use HYD. oil for the power steering, it has anti foam, anti corrosion additives, it is 10 wt, same as what is called for (10 wt. mo) only a lot better oil
