M916 Replacement Transmissions
Mark2X2
Washburn, WI
Just curious, I see a listing for a M916, it says it has a 9 speed transmission, shows a shift lever and clutch pedal. I have driven quite a few in active duty and reserves, all had the Cat 16 speed. Is this a replacement transmission or did Uncle Sam have them with 9 speeds. Can't post it or I will get in trouble, PM and I could tell you where I saw it.
goodguyzy
13
medford oregon
The only other tranny other than the original cat 7155 is the Allison HT4070 7-speed upgrade. Sounds like someone has done some custom work.
Mark2X2
Washburn, WI
You may be mistaking the Jake Brake actuating pedel with a clutch pedal. I've never seen a military M915/916 or other 900 models with a manual transmission.
I have driven M916 & M920's, I own 3) civilian tractors I know what I'm looking at. It is a clutch pedal and shift lever.
PM sent also you look at it
Bolkbich
MAHWAH, NJ
I saw that truck last week, its definitley a road ranger and thats definitley a clutch pedal. I cant tell if they left it 6x6 though. I'd bet its an air actuated clutch set-up.
