M215
- 3
- 18
- Spotsylvania, Virginia
Hello All,
We just brought home a set of wheels (2 pc. bolt together combat style) and tires (1400 x 20s) off of a M916. My question is if the wheel offset on the M916 is the same as those used on the supper single wheels found on the M813. Currently we are running 1400 x 20s mounted on Hemitt wheels without any issues on the M813. We flipped the rear axle hubs so all the wheel bolts are facing out. Second question, the M916 wheels still have the CTS valve body thingys attached, once removed do these have any value?
Thank you, Karl
Thank you, Karl
