M917 have CTIS?
98hd
Reedsburg, WI / Trenary, MI
I am in the region of WI that had the bad floods, and the NG here has been helping out. So at work I get to see a bunch of M917 dump's drive by all day long (makes it hard to do work).
Once in awhile one will get stopped at the light right outside the window. I just was checking one out and noticed hoses coming from the hubs on the back duals. I can't imagine what else it would be except CTIS. Is it very common on those trucks? I've never seen one before w/ that system, and never before on a truck w/ duals. I did not notice any hoses up front. Is it just a rear only system on these trucks?
Crash_AF
Colorado Springs, CO
The A2s had the singles and CTIS, the hoses on the rear were probably equalizers that connect the two duals together so they can be filled from one port and both match pressures. I've seen them on commercial trucks before.
Later,
Joe
tmbrwolf
Manhattan, Kansas
They may have a Y hose on the truck, makes it so you can fill both tires at the same time and keeps both tires air pressure balanced. I have "cats eye" system on out semi tractor and trailer at work, does the same think except it has a visual indicator that lets you know when the pressure is getting low.
BKubu
1,123
Gaithersburg, MD
CRASH_AF: He is referring to the Freightliner trucks, I believe, NOT the BMY produced M939A2 series trucks.
98hd
Re: RE: M917 have CTIS?
Right, I am looking at the Freightliner 915 series trucks. I wish I had a camera here I would try to snap a pic.
