- 2,295
- 866
- 113
- Fargo ND
Hello Guys and yes I have gone through enough TMs to just about make my eyes bleed on this issue, I now ask for your ideas please! I have a 1980 M920 and when I had it delivered last Wed. it was very cold and the batteries were weak, so of course it would not start, in fact it could just bump the started solenoid and that was about it. When I got into the cab I did notice the speedometer was bouncing between 0 and 20 mph, it would go down to 0 sit there a few seconds then go up to 20 mph and drop back to 0 again? Well I got the truck into my heated shop and got the batteries charged back up to full power and this morning put it all back together and hooked up the 12 Volt wire and I could hear the speedo doing its same thing as before, well I wanted to see if the truck would start so I crawled in the cab and the truck fired up instantly, yet again the whole time the speedo was doing its little dance, it does it whether the engine is running or not. Truck ran great I let the engine temp come up to about 150 degrees, it was running 60 psi for oil pressure at 800 rpm and the air pressure came up to 110 psi. But the speedo is drawing current from the 12 volt side every time it does its thing and I cannot find anything in the TMs that address this in any way, needless to say I am very open to any ideas on what I am missing here, I also unhooked the 12 volt wire when I shut the truck down this morning because it will continue to draw battery power regardless of ignition switch position.
If its any consolation the truck seems perfect and everything else seems to be as it should be! Let me know your ideas on what I am missing in this picture folks?
Thanks much
Karl
Thanks much
Karl
