M920 - manual tachometer needed
farmer73
14
Franklinton, NC
Is there a manual tachometer that operates based on the spinning of the internal portion of its cable and requires NO 12v or 24v power source?
1980 M920 Cummins NTC400 - speedo/tacho not working; truck starts and runs for 20 seconds then quits. Would be interested to the know the RPMs at all times without electrical issues blocking it.
Thanks!
kubotaman
124
RI/MI
If you are just trying to see what the RPM is for testing purposes, you can use a regular M-series Tach like on your M818 or M35A2. The tach drive and cable should match up
