M920 ring and pinion
catchem
pittsfeild pa
I'm trying to find ring and pinion for my 1980 m920. I can't find a part number or vendor that has knowledge on the axles. Any help would be appreciated. I'm looking for 4.56 ratio or a set close to that. Or the lowest I can get and still keep my lockers.
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
4.88 is the lowest and keep the lockers. That is when the spool changes
They are all available. Use the standard listings below.
You will have to swap the whole front axle with an FDS18 or 21 from a front discharge mixer. It's the cheapest option
If you are trying to go faster it's cheaper to swap the transmission or increase tire size.
catchem
pittsfeild pa
Thanks for the info.
catchem
pittsfeild pa
I have decided to switch transmissions due to the front oil seal leaking on the cat 7155. I removed the tranny and replaced with a Eaton 18 speed. I’m selling the entire system for the cat 7155 from a brand new shifter on down to the output shaft yoke. What is a fair price for it knowing it needs a front seal. Everything else is in excellent shape only 20k miles on it.
